Hello everyone.
I would like to adjust the transparency of the glasses of a model in all views (elevations, sections, perspectives, etc …).
I’ve been trying to touch the material parameters but I can not change the model in revit.
Does anyone know how I could do this? Thank you
The problem with doing that is that all the window glass and frame, becomes transparent, and I just want it to be glass that is changed.
Thank you
Thank you all. Something like what you say is what I had tried, and I get change transparency in the 3D view, but I could not change in elevations and sections.
In fact, 3D views transparency changes rapidly changing transparency revit material, without using dynamo.
Thanks again.
I don’t think that revit has ever supported transparency in elevations and sections. The most common solution is to hide the “glass” extrusion for those views:
http://forums.augi.com/showthread.php?25286-Making-the-windows-transparent-in-the-elevation
Thank you very much for answering.
Indeed it seems that is as you say.
I’ll try to hide the glasses, but it’s what I want. I would like to insinuate the background, not see it clearly
This discussion i was involved in a while ago might help re the transparency in elevation
