Hello everyone, I have a problem in controlling the visibility (Transperancy) of the point Cloud within Revit environment , this feature is easily found in AutoCad, I don’t know why Revit doesn’t have such a thing , would anybody help ?
you can override single colour….which is light colure like that…
good idea but i want something more effective
Point-cloud transparency cannot be adjusted with Dynamo at this time, due to the limitations of the rendering in Revit.
One way to reduce the visual impact of the point-cloud data in Revit is to reduce point numbers by space or Octree in the linked file. This can be done to some extent within Autodesk Recap when point-clouds are indexed to .rcs files, but for further procesing options external software would need to be used.
Thank you what are the examples of these software?
