Hello, good afternoon, I am new to python and I am trying to create a script that changes the numbering of planes, in this example I have from 101 to 105, the most I have been able to change is replacing “10” with “20”, resulting in 201 to 205, but I would like you to renumber, for example, from 101 to 105 by 118 to 122 with inputs, I would greatly appreciate some advice
Hi Piero, welcome to the Dynamo Forum ![]()
SheetNumber values are strings so to be able to do mathematical operations there needs to be some conversion to a number type and then back to a string for updating
n = 17
newNumber = str(int(sheet.SheetNumber) + n)
Here have a look at this snip might help you, as here u can give the initial value that u wish to start your numbering from as in this example i wanted it to start from 118 and it’ll number rest starting from there but here i’m giving input as int so modify accordingly if it helps.
Regards,
BM
Thank you very much for the advice
