Hi All,
How to change Naming Category of Assembly using dynamo.
Please suggest me
Thanks in advanced
hi @robert12546358,
I just have a short question.
Does all your assemblies contain object with Walls category?
-biboy
hi @robert12546358,
try this: change_assembly_name.dyn (7.9 KB)
just change the second Category to any category you want but it should exist in your assemblies.
it should look like this:
python script:
clr.AddReference("RevitAPI")
elements = UnwrapElement(IN[0])
for el in elements:
param = el.LookupParameter(IN[2])
param.Set(UnwrapElement(IN[1]).Id)
OUT = elements
cheers!
-biboy
it’s get a error & result is null.
File “”, line 18, in
EnvironmentError: System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
at Element.setParameterValue(Element* , ElementId , ParameterValue* )
at Autodesk.Revit.DB.Parameter.Set(ElementId value)
at Microsoft.Scripting.Interpreter.FuncCallInstruction3.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame) at Microsoft.Scripting.Interpreter.LightLambda.Run4[T0,T1,T2,T3,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3) at Microsoft.Scripting.Interpreter.DynamicInstruction4.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
at DSIronPython.IronPythonEvaluator.EvaluateIronPythonScript(String code, IList bindingNames, IList bindingValues)
since it is error, it should be null. did you restart your revit? also if possible, can you share a sample file.
-biboy
I share sample file.
hi @robert12546358,
my script run well in your file, please check:
your file (changed parameter value):
dynamo:
-biboy
Yes, it’s working in new dynamo file.
Thank you so much.
