Hi All,
I need some help, but first the scenario; i need to change the angle of my air terminals attached directly on my round duct.
So after my heating and cooling loads, i draw my duct and size according to results. I then need to change the angle of the air terminal directly on the duct based on the duct size. foor example if duct diameter is Ø400 then the angle should be 45 DEG.
I cannot figure out what nodes to use to get and set the parameters for me.
If i can get this automated using Dynamo it will save me such a lot of time!
Regards
Gary (trying my luck at Visual Programming and still going through the basics)
