XalhanB
1
Hi all,
I am having issues with Dynamo pulling out the Width Parameter from a Default Duct. The script i have written only selects ducts by there element ID.
Instead of it giving me the width of the duct as 305mm it comes back with 1.00065…
Could anyone think of a issue that could be causing this?!
You should change units from feet to millimeters. You are getting feet.
Cheers
@XalhanB
The width would be a type parameter i guess
you can probably get that by using Element.ElementType before the ElementParameterValueByName
XalhanB
4
Thanks for the quick response, i have now added the node Convert units for Feet to MM and it has fixed it.
