Continuing the discussion from Ceiling.ByOutlineTypeAndLevel not acknowledging islands:
Ceiling Sample.dwg (349.5 KB)
TEST.dyn (55.5 KB)
What I’m missing here?
I’m trying to create ceiling in this area
Hi @vishalghuge2500 that node expect list of curves in the right order, i havent tried your dwg but many things can go wrong if you cant create closed loops for surfaces, then you probably need to do some repair
@vishalghuge2500 Everything is perfect, but you need to connect curves, not polycurves.
