Categorize the elements by warning error message
I am trying to remove warnings in Revit 2017. is there any to Categorize the elements by warning error message. then I can isolate and eliminate the error by reviewing one by one.
Warnings.dyn (9.9 KB)
Maybe GroupByKey ? The warning error as key :slight_smile:
I tried its not working…:frowning: :upside_down_face:
What about the “affected elements”? They are grouped by error message? :slight_smile:
No, actually this data from exported HTML file…
Can you upload the html report? :slight_smile:
Sure…
HTML file
And maybe the Revit file :smiley:
What does this gives you?
See my image.
Don’t create a line from “File Path” to the Parse.ErrorReport in the buttom :slight_smile:
The “affected elements” are the list and the “error messages” are the func.
I don’t think its dos the job…:frowning: is there any other way isolate the warnings in Revit 2017.
Too sad.
I can’t recreate the problem (dno why), so I don’t think I can help you further. Sorry.
@CVestesen thank you mate… if I find anythink further I will share here…
Here I got…
isolating revit warnings by category
and here somethink is the result…
Try the Bang package
Maybe it helps
The GetWarnings() method unfortunately won’t work for Revit 2017…so far i know…:frowning:
See if this works …
errorReport.dyn (11.7 KB)
fil01 = DSOffice.Data.ImportCSV(errRpt);
rpt01 = String.Remove(List.DropItems(List.DropItems(String.Concat(List.Transpose(fil01)),3),-1),0,4);
//Elements
eID01 = List.TakeEveryNthItem(rpt01,2,0);
eID02 = String.AllIndicesOf(eID01," id ");
eID03 = String.ToNumber(String.Substring(eID01,eID02+3,7));
elm01 = Revit.Elements.ElementSelector.ByElementId(eID03);
//Error Messages
err01 = List.TakeEveryNthItem(rpt01,2,1);
err02 = String.IndexOf(err01,">")+3;
err03 = String.LastIndexOf(err01,"<") - String.IndexOf(err01,">") - 5;
err04 = List.TakeItems(String.Substring(err01,err02,err03),List.Count(eID03));
@Vikram_Subbaiah thank you…but I got Null
@_Vijay Try deleting a line and reconnecting as shown in the image below. Would like to see what you get
