Using Dynamo 1.2.0.2690 and Revit 2016 I am having problems when collecting window tags to read tag text with categories “window tags” and All Elements of Category node:
If tagged elements are in a linked file I get ‘failed to get tagged parameter’
if tagged elements are local it directly crashes revit.
Is there any known problem with this way of collecting tags?
Thanks John.
Tried your suggestion but same thing goes on. It directly crashed dynamo & revit.
I only have the categories and all elements of category nodes in the definition. Nothing else…
I have been getting the same problem with both reading the tag information in and trying to create them. I’m using category and multi-category tags which I created, but in Dynamo, my Revit crashes every time it passes through any of the Tag.By… Nodes, including the one made by ArchiLab. I am also using Revit 2016, but on Dynamo 1.3.
