Hello All,
I’m using Revit 2016 and Dynamo 1.3.3 I have an problem when i’m running my script. The script is collecting all the categories and all the elements from the model, but i get the error f"Exception: fail to get the tagged parameter."
I hope that someone could tell me why i’m getting this error.
marc
model_check_algemeen(2018-10-08).dyn (9.1 KB)
Hi @marc_franken,
I could see two things:
When you test if the view is a template, the property is e.IsViewTemplate
When you create the iCollection, you need to create en empty List and then use Add to “fill” the list with the ids:
ex_lst = List[ElementId]()
for i in ex:
ex_lst.Add(i)
When I make the changes above, I get an output, but I wont/can’t determain if it’s what you are after
. I’ve attached the dyn that worked for me.
model_check_algemeen(2018-10-08)_ForMarc.dyn (10.5 KB)
PS: It was done with a simplified version of what you are attempting though.
Hi @MartinSpence
i downloaded your file but i got an error that the file was corrupt. So i made the changes that you said in my own script but i stil get the same error.
thank you for your time and effort. I hope tou haven an another idea
marc
Ah, sorry for the corrupt upload. Don’t know what went wrong.
Regarding the python script, I ran it again with the entire list and I am getting an output. Although I failed to notice, that you are on Revit 2016. Im afraid I don’t have access to that at the moment.
This is in 2018 Dynamo 1.3.2:
import sys
# Import RevitAPI
clr.AddReference('RevitAPI')
#from RevitServices.Transactions import TransactionManager
tekst = []
viewcoll = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views)
ex = []
for e in viewcoll:
if e.IsTemplate == True:
ex.append(e.Id)
pass
ex2 = List[ElementId]()
for i in ex:
ex2.Add(i)
collection = FilteredElementCollector(doc).WhereElementIsNotElementType().Excluding(ex2).ToElements()
sb_list1 = []
for e in collection:
if e.Category != None:
sb_list1.append(e.ToDSType(True))
Material_list = []
Level_list = []
FillPatternElement_list = []
FloorPlanView_list = []
Element_list = []
GraphicsStyle_list = []
Electrical_list = []
SunAndShadow_list = []
PanelSchedule_list = []
CeilingPlanView_list = []
ElevationMarker_list = []
SectionView_list = []
AreaScheme_list = []
Phase_list = []
Project_list = []
Revision_list = []
AxonometricView_list = []
Zone_list = []
BasePoint_list = []
ParameterElement_list = []
PropertySetElement_list = []
PipeSegment_list = []
MechanicalSystem_list = []
Sheet_list = []
DetailCurve_list = []
ReferencePlane_list = []
Grid_list = []
ScheduleSheetInstance_list = []
Viewport_list = []
DraftingView_list = []
PipingSystem_list = []
View_list = []
TextNote_list = []
RevitLinkInstance_list = []
Curtain_Panel_list = []
M_Grid_Head_list = []
Space_list = []
LoadCase_list = []
Dimension_list = []
FilledRegion_list = []
RevisionCloud_list = []
MEPSystem_list = []
list_out = []
for k in sb_list1:
x = str(k)
if x == 'Material':
Material_list.append (k)
elif x.startswith ('Level'):
Level_list.append (k)
elif x == 'Element':
Element_list.append (k)
elif x == 'LinePatternElement':
FillPatternElement_list.append (k)
elif x == 'GraphicsStyle':
GraphicsStyle_list.append (k)
elif x.startswith('Electrical'):
Electrical_list.append (k)
elif x.startswith('SunAndShadow'):
SunAndShadow_list.append (k)
elif x.startswith('PanelSchedule'):
PanelSchedule_list.append (k)
elif x.startswith('FloorPlanView'):
FloorPlanView_list.append (k)
elif x.startswith('CeilingPlanView'):
CeilingPlanView_list.append (k)
elif x == 'ElevationMarker':
ElevationMarker_list.append (k)
elif x.startswith('SectionView'):
SectionView_list.append (k)
elif x == 'AreaScheme':
AreaScheme_list.append (k)
elif x == 'Phase':
Phase_list.append (k)
elif x == 'Revision':
Revision_list.append (k)
elif x.startswith('AxonometricView'):
AxonometricView_list.append (k)
elif x == 'Zone':
Zone_list.append (k)
elif x == 'BasePoint':
BasePoint_list.append (k)
elif x == 'ParameterElement':
ParameterElement_list.append (k)
elif x.startswith('Project'):
Project_list.append (k)
elif x.startswith('PropertySetElement'):
PropertySetElement_list.append (k)
elif x == 'PipeSegment':
PipeSegment_list.append (k)
elif x == 'MechanicalSystem':
MechanicalSystem_list.append (k)
elif x.startswith('Sheet'):
Sheet_list.append (k)
elif x == 'DetailCurve':
DetailCurve_list.append (k)
elif x == 'ReferencePlane':
ReferencePlane_list.append (k)
elif x == 'Grid':
Grid_list.append (k)
elif x == 'ScheduleSheetInstance':
ScheduleSheetInstance_list.append (k)
elif x == 'Viewport':
Viewport_list.append (k)
elif x == 'DraftingView':
DraftingView_list.append (k)
elif x == 'PipingSystem':
PipingSystem_list.append (k)
elif x == 'View':
elif x == 'TextNote':
TextNote_list.append (k)
elif x == 'RevitLinkInstance':
RevitLinkInstance_list.append (k)
elif x == 'Curtain Panel':
Curtain_Panel_list.append (k)
elif x == 'M_Grid Head':
M_Grid_Head_list.append (k)
elif x == 'Space':
Space_list.append (k)
elif x == 'LoadCase':
LoadCase_list.append (k)
elif x == 'Dimension':
Dimension_list.append (k)
elif x == 'FilledRegion':
FilledRegion_list.append (k)
elif x == 'RevisionCloud':
RevisionCloud_list.append (k)
elif x == 'MEPSystem':
MEPSystem_list.append (k)
list_out.append (k)
OUT = list_out
Sorry, but I can’t seem to replicate the error you are getting.
Hi, @MartinSpence
thank you for your time again.
I tested the script on an other model and there it worked fine. So i think that the problem is in the first model. So i will look more into that model to find the problem. The script is working now on an model in Reit 2017.
marc
