Hi All,
I started playing around with setting catchment values. One I can’t get to work is setting a catchment’s reference structure. I tried the below and it didn’t work but no errors are thrown. Anyone have any ideas? Thanks!
Hi @KirkWM,
I don’t have C3D 2021 and can’t test this, but I expect that you can’t use the structure name as input because that property does not have a “set” method.
So I think you need to use the ReferencePipeNetworkStructureId and provide the object ID as input.
