Catchment and structure
I try to set reference structure and catchment. How associate structure and catchment?
I have already do this:
Trying
Get structure buy it name
Please analyze script more precisely, I think solution is more complicated.
Can you attached example drawing
And
Example file Dyn
Attached
CatchmentExample.dwg (1.0 MB)
StructureCatchment.dyn (37.3 KB)
I will try this
And can you see this solution
Thanks, but your script give the same result as mine. I’m don’t know, how associated geometry point from centre od structure with structure and catchment. How “change” geometry point to appropriate structure?
Thanks! Problem solved!
