hello community,
I would like to make a script to encode all my presentations via Dynamo. I’m blocking on graphics properties. I would like to repeat these phases by checking off what I need for each presentation.
I started but I think I’m on the wrong path.
Thanks in advance
TEST_DY.5_Encodage_Cartouche.dyn (72.0 KB)
MVE1112
November 22, 2022, 1:31pm
2
The value for yes no parameters is usually 0 or 1. So you could set the parameter you want to 0 for no and 1 for yes.
The script is correct to extract these parameters? Or am I missing something?
MVE1112
November 22, 2022, 1:47pm
5
Well, you have to tell the ‘set parameter’ node which parameters you want to set, you are not supplying an input to the parametername field
The second part of your graph isnt correct, you setting both key and value to the same element. What is your goal?
I would like to have these choices (see photo below)
in this knot (see photo below) and apply it in the sheets I have selected
TEST_DY.5_Encodage_Cartouche.dyn (72.5 KB)
