I tend to agree with this sentiment, but, I do believe this is a result of the unit changes finally being done in this release.(https://thebuildingcoder.typepad.com/blog/2021/04/pdf-export-forgetypeid-and-multi-target-add-in.html#2)
I think the built-in set parameter by name node isn’t converting to whatever ForgeTypeId is needed for that node. (I am honestly a bit surprised that method ever worked because setting parameters by name for stuff like that has historically been buggy)
That being said, I would definitely report it on GitHub because they might be able to fix that on the Dynamo side of things.
If it were me, I would be using something that sets that parameter very specifically with the builtinparameter name as documented here, https://thebuildingcoder.typepad.com/blog/2013/01/change-element-workset.html.
And clockwork does this really well:
“But I don’t want to Use Packages”
Also, doable in python (CPython3 script below)
# import Revit API
from Autodesk.Revit.DB import GraphicsStyle,ElementId,Element,BuiltInParameter
# import Dynamo Revit Services
# custom def for setting workset
def SetWorkset(element,workset):
param = element.get_Parameter(BuiltInParameter.ELEM_PARTITION_PARAM)
# set based on type
if isinstance(workset, GraphicsStyle):
param.Set(workset.Id.IntegerValue)
elif isinstance(workset, ElementId):
param.Set(workset.IntegerValue)
elif isinstance(workset, int):
param.Set(workset)
return element
# inputs
elements = UnwrapElement(IN[0])
workset = UnwrapElement(IN[1])
# return the results
if isinstance(IN[0], list): OUT = [SetWorkset(x,workset) for x in elements]
else: OUT = SetWorkset(elements,workset)
