Can't get volum from sliced polygon
Hello, I’m creating a script to get sliced solids along a corridor. The script runs well but when I’m trying to get the volume from the sliced polygons I get the following warning:
Any clues? Thank you.
Hi @Juantxo76,
The solids that are created are AutoCAD solids, not Dynamo solids. So you’d have to use Object.Geometry first and then read the volume.
Thank you @zachri.jensen it works perfect now.
