I got solids from corridor, but I cannot get the volume.
Object.Geometry node
Between 2 the nodes
thanks. seems some solids have problem, my dynamo freezes up.
any other method to extract its volume?
The Object.Geometry node, then Solid.Volume should work, but alternatively you can get the automatic volume property generated during solid extraction using the property set nodes.
Converting from one geometry system to another can be time consuming. Either let it take it’s time or look into pulling a property of the solid itself using the AutoCAD api.
thank you so much! where does the get_volume() comes from? is it a dynamo design script or api?
does it have get surface also?
Get the object as input for Python code node and write OUT = dir(input). This way you can get methods or properties from api. More here https://youtu.be/6NUu4sRMkTU?si=yjCD1Z-4qhdd1qF0
