Hello!
I tried to export the data from Dynamo to Excel, using the solution of @Michal_Dengusiak. I extracted the volume and base level, but I can’t get the URL, price etc.Dynamo also doesn’t see that parameters. I will be grateful for any help and suggestions. Thanks!
URL is a type parameter - you are pulling instance parameters. Just search for “get type parameter” on the forum.
Thanks a lot! Now it’s clear!
I don’t know that node but it looks like you might need to flatten your list of values.
Set Type Parameter from Archi-Lab. Tried to use Flatten. I suppose the problem is in that node. Could you advise please if there is another way to get the right result to set such type parameters. I just want to operate with that using Excel. Thanks in advance!
Found the solution. Used Element.Type before Set parameter by name
