Can't get geometry from Parcels
Hello everyone,
I recently upgraded to Civil3D 2025 to gain access to some of the new features in Dynamo. However, it seems that some features were also lost. I used to be able to extract geometry from parcels, but that node isn’t working anymore. Does anyone have any advice for getting the geometry from parcels loaded into Dyanmo?
Thank you,
Hi @Ian_duPont
Perhaps you’re referring to a node from a package? Getting parcel geometry has not been available in the base product historically, and that is still the case.
@zachri.jensen
That is very possible. I’m new to Dynamo so I probably didn’t realize that was a node from an external package. I’ll dig around and see if I can find which package that node was in.
If anyone has any ideas of which package that may have been from, let me know.
Thank you!
Arkance and Civil3D Toolkit both had nodes for this which worked pre-2025.1 and pre-2025. I haven’t see a work-around in 2025 yet.
@jacob.small
I see the same thing when looking into Civil3D Toolkit. We may need to revert to 2024 to continue moving.
Thank you,
