Can't find dynamo nodes in civil 3d toolkit
I have multiple lines, assembly and FGL surface and I need to create a multiple Corridors and surfaces from each line separately. I found resources to create what i need but the used nodes is missing from my civil 3d toolkit. I tryied to uninstall and install many versions but still can’t solve the problem. I am using civil 3d 2025.
please attach your dynamo and drawing example to get help from members.
In 2025 you need to use ”Civil Nodes” created by @Anton_Huizinga
C3D Toolkit is for 2024 and earlier versions
Not all nodes from the C3DToolkit are available in The Civil Nodes, but there are many on the wishlist.
Hi @omar_alaaAQXDV,
Could you give some more insight into which nodes you require?
As Patrick replied it is a compatibility issue with 2025. I installed civil 3d 2024 and found the missing nodes
Many civil 3d toolkit nodes are not available in civil 3d 2025.
For example
AlignmentExtensions.CreateAlignmentByPolyline
AlignmentExtensions.AddProfileByName
AlignmentExtensions.AddPVI
Thanks Patrick for your help.
