I migrated from Civil 3D 2024 to Civil 3D 2025. In Civil 3D 2024, Dynamo had many more nodes available, such as Select Objects, but in Dynamo inside Civil 3D 2025 I don’t have them. What could be the cause of this issue?
The node Select Objects was part of the C3DToolkit, which is not compatible with Civil 3D 2025. This particular node was added to Civil 3D 2025.2 if I remember well.
There are more topics you can explore about the changes between 2024 and 2025:
