Can't change the symbol parameter value
I have pile foundation family with image parameter (Paalsymbool)
I created with a lot of help from you all a Dynamo Graph to retrieve the correct name but the value from (Paalsymbool) won’t change if i take for example (Comments) it changes correctly.
Is there a way to correctly change parameter (Paalsymbool) ??
thanks Edwin.
got it solved
The value of an imageparameter can only changed with ImageType in the Element Types node
Edwin
