Can you help me to fix this file
i just learning dynamo, and i want to make a tool about ‘make button list for selection category’ follow a instruction but i can’t run. pls help me to find what’s wrong in my file.
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Platforms\Net40')
try:
	clr.AddReference('System')
	clr.AddReference("PresentationFramework")
	clr.AddReference('IronPython.Wpf')
except IOError:
	raise
from System.Windows import Application, Window
from System.IO import StringReader
try:
	import wpf
except ImportError:
	raise
class DropdownInput(Window):
	LAYOUT = """
			<Window
				xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
				xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml">
				xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
				xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
				xmlns:local="clr-namespace:WpfApplication1"
				mc:Ignorable="d" Height="140.139" Width="325" ResizeMode="NoResize"
				Title="" WindowStartupLocation="CenterScreen" Topmost="True" SizetoContent="WidthAndHeight">
				<Grid Margin="10,0,10,10">
					<Label x:Name="selection_label" Content="Select Item" HorizontalAlignment="Left" Height="30"
						VerticalAlignment="Top" Width="299"/>
					<ComboBox x:Name="combo_data" HorizontalAlignment="Left" Margin="0,30,0,0"
					<Button x:Name="button_select" Content="Select" HorizontalAlignment="Left" Height="26"
					Margin="0,63,0,0" VerticalAlignment="Top" Width="299"/>
				</Grid>
			</Window>
	def __init__(self, title, options, description=None):
		self.selected = None
		self.ui = wpf.LoadComponent(self, StringReader(DropdownInput.LAYOUT))
		self.ui.Title = title
		if description is not None:
			self.ui.selection_label.Content = description
		self.ui.button_select.Click += self.select_click
		self.ui.combo_data.Items.Clear()
		self.ui.combo_data.ItemsSource = options
		self.ui.combo_data.SelectedItem = options[0]
	def select_click(self, sender, e):
		self.selected = self.ui.combo_data.SelectedItem
		self.DialogResult = True
		self.Close()
run = IN[0]
keys = IN[1]
values = IN[2]
description = IN[3]
if values:
	if len(values) != len(keys):
		raise Exception('Length of Values and Keys must match')
	dropdown_options = {k:v for k, v in zip(keys, values)}
	dropdown_options = {k:k for k in keys}
if run:
	form = DropdownInput('Dynamo Form Input', dropdown_options.keys(), description=description)
	form.ShowDialog()
	if form.selected is not None:
		OUT = dropdown_options[form.selected]
	OUT = 'Set RUN to True'
hi,
there are some little errors in your xaml, try this
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\DLLs')
try:
	clr.AddReference("IronPython.Wpf")
	clr.AddReference('System.Core')
	clr.AddReference('System.Xml')
	clr.AddReference('PresentationCore')
	clr.AddReference('PresentationFramework')
except IOError:
	raise
from System.Windows.Markup import XamlReader, XamlWriter
from System.Windows import Window, Application
try:
	import wpf
except ImportError:
	raise
	LAYOUT = """
			<Window
				mc:Ignorable="d"
				Height="140.139"
				Width="325"
				Title=""
				Topmost="True"
				SizeToContent="WidthAndHeight">
				</Grid>
			</Window>"""
		self.Close()
run = IN[0]
keys = IN[1]
values = IN[2]
description = IN[3]
if values:
if run:
	form.ShowDialog()
When I try to start it in Pythonshell - it work!
When from Dynamo - next error:
ImportError: No module named _wpf
How to fix it? please help
Hello @y.Petrenko
Which Revit version are you using ?
Hello
My Revit is 2022.1
I never had this error, there may be a conflict with an addin
EDIT
try to replace this
try:
	import wpf
except ImportError:
	raise
by
try:
	import wpf
except ImportError:
	from IronPython.Modules import Wpf as wpf
Hi Ciryl
After a lot of test you are right - there is conflict with pyRevit
How I understand it? I have on work a clear PC
all is work good just as “import wpf” or “from IronPython.Modules import Wpf as wpf”
but when install pyRevit we have next problem:
option1 - “from IronPython.Modules import Wpf as wpf”
option2 - import wpf
:worried:
maybe you have some idea what is it? maybe we have to use another wpf,py file? or, i dont know
in additional path and contains of my wpf.py
I found solution for me:
topic here:
Need to do:
Delete Generative Designe pack
Use in pyRevit the 2711 engine
thanks all for attention!
