Hello forum,
i’m able to create “ELBOW FITTING” by using “Elbow.ByMEPCurves” Node by giving all the ducts(MEPCurves) as a input.
But,coming to “Tap.ByMEPCurves” Node it has two inputs, one is “Main MEPCurves” and “Branch MEPCurves”. So that it is difficult to seperate the “MAIN MEP CURVES” and BRANCH MEP CURVES" if we have more in number.
Can we set the same input for the both nodes as “MEPCurve” so that it will be easier to give all the MEPCurves at once.
