Can’t find the rhythm node ‘all upper’
Hi. I am looking to change my view Titles (viewports) alll to upper case using Dynamo.
I m quite new at Dynamo and I´ve follow THIS EXPLENATION where it says the Rhytm Package is a go.
I´ve downloaded the package, installed it and here´s my question: Once added the package to dynamo folder, how do I use the command node? I cannot find All upper in the left command bar when I type it meaning I cannot add the node to my screen.
Any other solutions on chagin all the view title names to upper case are welcome :slight_smile:
you can use the one built-in in dynamo from " Core --> String --> ToUPPER node
if your view title linked with sheet name:
if if your view title linked with Appear on sheet parameter:
from Rhythm Package it’s located under Tool sublist
