Hello, I am creating an organic facade, I already set everything and now I need to send it from dynamo to revit but the only node to create forms that I find is byLoftCrossSection and this dosent work form me, I need something like create form by patch. Is there any way to do it. The other solution would be add thinkness to the dynamo patch and then use the ImportInstance.ByGeometry node but then I would be able to add material to those surfaces.
Thank you for you time
