It’s Read-Only Parameter
Thank
this part have a profile right? you will need to play with the profile geometry instead. it wont be as easy as the previous post
I can’t edit part profile because it created by wall.
but it is possible to manually adjust the height of the part?
Yes but I try to find solution to set via dynamo to faster.
then edit the wall height directly.
It is possible with the api, here is a sample https://thebuildingcoder.typepad.com/blog/2012/09/parts-assemblies-partutils-and-divideparts.html
GeometryElement geomElem = part.get_Geometry( new Options() );
foreach( GeometryObject geomObject in geomElem.Objects )
if( geomObject is Solid )
Solid solid = geomObject as Solid;
FaceArray faceArray = solid.Faces;
foreach( Face face in faceArray )
if( part.CanOffsetFace( face ) )
part.SetFaceOffset( face, offsetCtr );
offsetCtr += 0.1;
https://www.revitapidocs.com/2016/6d2cb1e0-1754-8f71-f02f-70c153fe6bde.htm
seems like you can do it using api. thanks @Einar_Raknes
