hi,
So i created in 2022 a python costum node and it says:
if isinstance(rooms,list): rooms = UnwrapElement(rooms)
else: rooms = [UnwrapElement(rooms)]
Can i ignore that?
KR
Andreas
@Draxl_Andreas Can you please share the whole code?
Possible solution: You also try using your learnings from your post below for this situation:
realy, so i just implement that “Try” as accepted! @AmolShah
here is this beautiful pice of art
@Draxl_Andreas not sure why you are getting that error, try the attached custom node:
RoomsGetRoomsParameters.dyf (9.6 KB)
roomsParameters.dyn (8.3 KB)
