How can I change the Sun's position (Date & Time) in Revit with Dynamo?
Possible? I only find Query nodes with 0.7.5.
Adding nodes to allow changing would be easy to add but at this point, it’s just query. What are you looking to achieve?
-matt
Animate sun movement, of course:) Could be possible with Python and API?
any luck?
i’m currently turning Dynamo script on automatic mode and moving sun manually in Revit, can it be done via Dynamo and/or Python / C#? i mean automatically moving sun
if you use solar study like this:
obraz
you can change the active frame via python:
clr.AddReference("RevitAPI")
view = UnwrapElement(IN[0])
frame = IN[1]
sunSettings = view.SunAndShadowSettings
sunSettings.ActiveFrame = frame
OUT = 0
obraz
cool, thanks maciek.
the only problem is how to integrate into existing Dynamo, i used frame list so for each frame, modification of Revit element is desired to be seen, in short, very similar to Revit OOTB Preview Solar Study.
hi,
I am not sure if I understood you correctly, but maybe you can delay the code after each frame iteration. Smth like that: https://www.pythoncentral.io/pythons-time-sleep-pause-wait-sleep-stop-your-code/
Don’t know though, how it will work in Dynamo.
right, but it will only work if i convert all Dynamo nodes into Python code, hope i’m wrong
I don’t know any other way…
Also it might be necessary to commit a transaction after each sun position shift to see the results…
I am not sure what you’re exactly after but maybe it would be easier to take image snapshots at each frame?
thanks maciek, didn’t work even if i added transaction inside frame loop, there’s no way to “synchronize” w/ Dynamo nodes, as i said before, element modification needs to be done inside Python
