woksets for revit links.dyn (44.4 KB)
This dyn is actually for eliminate the existing workset and to create &assign workset for the newly added Revit links. But its not working
What does the error say? I’m guessing it’s something about not being a numeric value. Provide the workset element instead of the Id and see what happens.
I checked with numeric one also but still not working. If i provide only one ID to the value its running fine.
Check the Object.Type of the worset Ids. They should be numbers. If they’re not, you need to convert them.
