Python Script For Family Path
Hello
I can’t seem to get the routine from here working.
I have been trying to use the Select Model Element node plugged straight into the Python script…
Hi @Ben_Veasey
the family instance is not “converted” to a family symbol in the link’s code.
Try this :
clr.AddReference('RevitAPI')
#Close all transactions
trans = TransactionManager.Instance
trans.ForceCloseTransaction()
dataEnteringNode = IN
fam = IN[0]
faminstance = []
path = []
family = []
for f in fam:
	faminstance.append(UnwrapElement(f))
for f in faminstance:
	family.append(f.Symbol.Family)
for f in family:
	famDoc = doc.EditFamily(f)
	if not famDoc.PathName:
		path.append('Family location not found')
		path.append(famDoc.PathName)
	famDoc.Close(False)
OUT = path
Thank you guys, that works great.
Hi @Mostafa_El_Ayoubi
Is it possible to set a new path name for the family even if this directory does not exist in you local computer?
Thanks!
