Calling FamilyInstance.ByPoint from Python
I get this error when trying to create familyinstance by point in python
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
dataEnteringNode = IN
point = IN[0]
familytype = IN[1]
try:
x = DSCore.FamilyInstance.ByPoint(familytype,point);
except Exception as e:
s = str(e)
OUT = s
You’re not passing any familytype or point to your script? :slight_smile:
For a moment there i doubted myself :sweat_smile:
Capture
I would be creating 100s of families for a check, so i want to do it in code as a for loop and create/del one instance it per loop.
Hah! I justed noticed it on your screenshot :D.
I’m not familiar with the DSCore method, so I cant help you further :slight_smile:
You don’t have to import DSCore but rather RevitNodes.
point = IN[0]
familytype = IN[1]
try:
	x = Revit.Elements.FamilyInstance.ByPoint(familytype,point)
	s = str(e)
OUT = x
Hi Alban,
Why don’t we need a transaction or to convert the point to Revit type? :smiley:
Cheers,
Mark
This is because the script calls the Dynamo node in python and doesn’t use the Revit API.
There is no need to unwrap the FamilyType, convert the dynamo point and use transactions.
The Revit API method is doc.Create.NewFamilyInstance(XYZ,FamilySymbol,StructuralType)
Hi Alban,
When trying to run the python script, this is the warning that shows up. Do you know why it is saying that x is not defined?
Thanks,Capture
Check your code, you may have an indentation problem.
The try and except lines are not essential and can be removed.
ByPoint
What do you mean by remove? Like all of lines 9 and 12?
When I place just one point, it works great, but when I have multiple points, it won’t run.
@callbowen: it’s probaly because your IN[0] becomes a list of points instead of just one point :).
To correct this, you need to loop through your points with a for loop:
“for p in points”:
x = Revit.Elements.FamilyInstance.ByPoint(familytype,p)
Edit:
You might find this thread useful regarding passing a list or not a list to your python script. :slight_smile:
