I’ve read through a few posts on here and i’ve tried a few things but cant quite get it working.
im trying to:-
get all elements of a category in the active view.
get family name of elements
filter out the elements based on the family name containing “???”.
#Import Revit Nodes
# Import RevitAPI
clr.AddReference("RevitAPI")
dataEnteringNode = IN
#Get the project document.
#Filter for category.
collector = FilteredElementCollector(doc, doc.ActiveView.Id)
filter = ElementCategoryFilter(BuiltInCategory.OST_DuctFitting)
category = collector.WherePasses(filter).ToElements()
familyname = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_DuctFitting).WhereElementIsElementType()
OUT = category, familyname
im getting all the elements in the category from the active view which is great.
but I cant get the ‘familyname’ to output the actual family name.
from there Id like to filter the elements by the family name so if it contains ‘Bend’ or ‘shoe’ etc
I’ve tried a few things with FamilySymbol, .FamilyName and AsString, based on other threads in on here, but always seem to end up with empty list or errors.
or is there a better way of going about it? finding all instances of a family type and just list out the ones i want to collect?
any advice would be great!
Thanks,
@T_Pover, @Kulkul, @awilliams
Now that you have the family type you should be able to get the family definition, then the name.
See below:
clr.AddReference('RevitAPI')
category = UnwrapElement(IN[0])
elements = FilteredElementCollector(doc, doc.ActiveView.Id)\
.OfCategoryId(category.Id)\
.WhereElementIsNotElementType()
filtered = []
for e in elements:
type_id = e.GetTypeId()
element_type = doc.GetElement(type_id)
family = element_type.Family
name = family.Name
if '???' not in name:
filtered.append(e)
OUT = filtered
What you are assigning to the ‘familyname’ parameter is actually just the FamilySymbol. Get the Family from the FamilySymbol and then get the Name from the Family (this is inherited from the Element class).
I should also note that the above code expects a single Category being provided to input IN[0].
another solution similar to that of cgartland
#Import Revit Nodes
# Import RevitAPI
#collection filter FamilyInstance in active view
FamInst_filtered = [x for x in FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_DuctFitting).ToElements() if "???" in x.Symbol.FamilyName]
OUT = FamInst_filtered
Thank you for your help guys! both methods worked for me!
I took this and @T_Pover code for MEP connectors
(i’m fining this incredibly useful!) and added a modified version of that to get the ducts connected to the fittings.
@cgartland - i ended up on that Family page quite a few trying to fiqure this out. API doc is starting to make a bit more sense…
#Import Revit Nodes
# Import RevitAPI
clr.AddReference ("DSCoreNodes")
import DSCore
from DSCore import *
shoe_ducts = []
taper_ducts = []
Shoes = [x for x in FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_DuctFitting).ToElements() if "Shoe" in x.Symbol.FamilyName]
Tapers = [x for x in FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_DuctFitting).ToElements() if "Taper" in x.Symbol.FamilyName]
for shoe in Shoes:
shoeset = shoe.MEPModel.ConnectorManager.Connectors
conn_shoe = []
for c in shoeset:
if c.IsConnected:
for sc in c.AllRefs:
conn_shoe.append(sc.Owner)
shoe_ducts.append(conn_shoe)
for taper in Tapers:
taperset = taper.MEPModel.ConnectorManager.Connectors
conn_taper = []
for c in taperset:
if c.IsConnected:
for tc in c.AllRefs:
conn_taper.append(tc.Owner)
taper_ducts.append(conn_taper)
OUT = shoe_ducts, taper_ducts
so i have a list of elements connected to all the fittings in the view.
sure theres a better way of doing but it works so im happy!
I have purposely added fittings directly after the tapers/shoes, as in this instance i want to find the ducts from these secondary fittings if that makes sense. so my current output has a mix of ducts and duct fittings.
How would i apply a category filter to the output lists already created (shoe_ducts/ taper_ducts)? i’d like to filter out the fittings from these lists, the get their connections & connected duct. (preferably within the same python script).
Or even better would be a loop where it takes the shoes/tapers, find the connectors and the connected elements.
if its a duct append to a list.
elseif its a fitting/accessory/mech equipment, find the connector and the connected element.
else if…
and repeat through until there is the first duct element after each taper/shoe connection.
something like this in dynamo but kind of endless until it finds a duct?
