I have a need to be able to read the data out of a schedule generated by a calculated values. If the value is less then a certain number than I want to have a view template indicate in red which elements do not comply.
This is for calculating shear value of some structural framing. See example below.
The red cells are deficient and I am using conditional formatting to fill those in. The user currently has to manually enter a “Y” in the comments in order for the beam to show up in red in plan.
I am tying to eliminate the user input.
I am just learning dynamo and need some hints on what I need to do this, if it can be done at all.
I’m not sure how to select the elements in that schedule to change the comment parameter.
It could be done by selecting beams themselves rather than going through the schedule. However, it would require you to re-create that calculated value in Dynamo. That formula doesn’t look too complicated. I gave it a try and this is what I came up with:
So a couple things I noticed.
1 & 2 Parameter Name contained a “-” I have recreated the parameter.
3 Corrected the formula to have the new parameter name.
That’s possible. Could you expand the results of the parameters too? It would be helpful to see what the actual values are to check the formula.
I’m wondering if this is even necessary. If the goal is to mark the doors with a Y if that value is negative you could do that with a calculated value. You could create a calculated value in your schedule that says if((X / 2-Y) <0, “Y”, “”). That should get the value to filter by.
I read through the Primer section and all of section 4 on data, however I am having an issue trying to see how strings will work in this situation.
In the simplest form I need to be able to read data from a schedule and if the data is a negative number I need to add a comment to a text parameter.
I have tried to perform the calculated value function or formula in Dynamo and I don’t think it is working. See #1 in the image. PhiVn / 2 - Start Reaction Total = Shear Check Start
But this is just a simplified example: you will need to pay attention that parameter values are extracted directly from the list of instances you want to filter, so as to maintain the correct items order
I am so close.
At one point it was placing the comment on all the Items and not just the negative value. Now it places the comment in select cells and I have no idea why.
