Is there a way to add a calculated value field for a schedule on dynamo instead of going to the schedule on revit and add a formula manually?
jad.diab
1
Did you every figure this out?
Related topics
| Insert column” in a schedule with “Calculated Value | 2 | 120 | April 4, 2025 | |
| "Insert column" in a schedule with "Calculated Value" | 14 | 2448 | August 4, 2022 | |
| Create calculated formula Schedule | 4 | 936 | April 5, 2022 | |
| Create Calculated Values in Schedules? | 2 | 1429 | July 23, 2018 | |
| Adding Calculated Parameter using Revit API | 4 | 390 | February 7, 2024 |
