When I link this drawing into Revit, the lines seems to have breaks at certain points. (Around 4mm) break.
However, when I check in AutoCAD, the line is a Polyline. Why did it even break when imported into Revit then?
I thought it might just be visually unjoined, so I tried using CAD.CurvesFromCADLayers, it’s the same.
hey @Potato Despite being line or polyline the CAD.CurvesFromCADLayers node will always return curves. You can do
1.GroupGeometriesByLayer node in LINKDWG package to get output as a polycurve.
2.take curves from CAD.CurvesFromCADLayers ,group the curves by Group Curves node from archilab package and then Polycurve.ByJoinedCurves to get a polycurve.
Hi there!
I tried the Group.Curve
That was what brought me to this problem.
I couldn’t see it at first, but after grouping, I see there were 4 lists instead of 2.
Whatever the case is, my friend suggested me to Untick this
I wanted to extract that Polyline from CAD to work on it
I need the extracted Curves to be 2 continuous line as it should be.
Group.Curve should come back with 2 groups of curve.
If I tick the box, apparently the CAD file that I link, will break itself at some points.
my Group.Curve will instead, come back with 4 groups of curves.
