C# help - How to read excel
This reads a csv file but I’d like to read an xlsx file (Excel file).
                sheetPath = sheetFile.FileName;
                // 2. read Excel file
                List<SheetData> sheetDataList = new List<SheetData>();
                string[] sheetArray = File.ReadAllLines(sheetPath);
                // 3. loop through Excel data and put into list
                foreach (string sheetString in sheetArray)
                    string[] cellData = sheetString.Split(',');
                    SheetData currentSheetData = new SheetData();
                    currentSheetData.SheetNumber = cellData[0];
                    currentSheetData.SheetName = cellData[1];
                    sheetDataList.Add(currentSheetData);
I tried adding the using OfficeOpenXml but got into a right mess.
I tried using Excel = Microsoft.Office.Interop.Excel which didn’t work either.
Anyone know an easy way to read excel?
This library looks like an option Excel Data Reader
I’m fairly sure interop is the best route here if you’re on Windows.
Heaps of documentation here and samples:
Hi @Alien ,
Over here an example how to read data from excel.
This script read all the data from every worksheet.
Did you create a Excel Application?
Excel.Application excelApp = new Excel.Application();
using System;
using System.Windows;
using Excel = Microsoft.Office.Interop.Excel;
namespace ExcelDataIntoOtherExcel
    /// <summary>
    /// Interaction logic for MainWindow.xaml
    /// </summary>
    public partial class MainWindow : System.Windows.Window
        public MainWindow()
            InitializeComponent();
        private void Button_Click(object sender, RoutedEventArgs e)
            string excelFilePath = "C:\\Users\\****\\Desktop\\****.xlsx"; // Replace with your path
            Excel.Workbook excelWorkbook = excelApp.Workbooks.Open(excelFilePath);
            try
                foreach (Excel.Worksheet excelWorksheet in excelWorkbook.Sheets)
                    string worksheetName = excelWorksheet.Name;
                    Excel.Range usedRange = excelWorksheet.UsedRange;
                    Excel.Range column = usedRange.Columns["A"];
                    // Read the values
                    object[,] values = (object[,])column.Value;
                    // Verwerk de waarden van de kolom
                    int rows = values.GetLength(0);
                    for (int i = 1; i <= rows; i++)
                        var cellValue = values[i, 1];
                        // Doe iets met de cellValue, bijv. print het op het scherm
                        //Debug.Print($"Worksheet: {excelWorksheet.Name}, Cell: A{i}, Value: {cellValue}");
            catch (Exception ex)
                MessageBox.Show($"Er is een fout opgetreden: {ex.Message}");
            finally
                // Sluit en maak de Excel-applicatie en het werkboek vrij
                excelWorkbook.Close();
                excelApp.Quit();
                ReleaseObject(excelWorkbook);
                ReleaseObject(excelApp);
            Close();
        private static void ReleaseObject(object obj)
            try
                System.Runtime.InteropServices.Marshal.ReleaseComObject(obj);
                obj = null;
                obj = null;
                Console.WriteLine($"Fout bij het vrijgeven van het COM-object: {ex.Message}");
            finally
                GC.Collect();
BTW, I guess you have more luck on the API forum :slight_smile:
Hi @Alien
To accsess Excel in Dynamo, you need use late binding to access the Excel API. This is because Dynamo is already accessing the Excel API. Challenges may arise when trying to access the API of another package, especially if Dynamo has already established a connection to it. This issue was solve by @zachri.jensen.
The below code to accses Excel by using late binding
    public static string Set_Value_at_Range(string workbookPath,string sheetName, string Range, string Value,bool Visible, bool save,bool Close)
                try
            // Specify the file path and name of the Excel file
            string filePath = workbookPath;
            // Use late binding to create an instance of the Excel application
            Type excelType = Type.GetTypeFromProgID("Excel.Application");
            object excel = Activator.CreateInstance(excelType);
            // Use late binding to open the Excel file
            object workbooks = excelType.InvokeMember("Workbooks", BindingFlags.GetProperty, null, excel, null);
            object workbook = workbooks.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, null, workbooks, new object[] { filePath });
            // Use late binding to access the first worksheet
            object sheets = workbook.GetType().InvokeMember("Sheets", BindingFlags.GetProperty, null, workbook, null);
            object sheet = sheets.GetType().InvokeMember("Item", BindingFlags.GetProperty, null, sheets, new object[] { sheetName });
            if (Visible)
                excelType.InvokeMember("Visible", BindingFlags.SetProperty, null, excel, new object[] { true });
            // Use late binding to add a value to cell "C3"
            object range = sheet.GetType().InvokeMember("Range", BindingFlags.GetProperty, null, sheet, new object[] { Range });
            range.GetType().InvokeMember("Value", BindingFlags.SetProperty, null, range, new object[] { Value });
             if (save)
                    // Use late binding to save the changes to the Excel file
                workbook.GetType().InvokeMember("Save", BindingFlags.InvokeMethod, null, workbook, null);
            if (Close)
                    // Use late binding to close the Excel file and quit the application
                    workbook.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, null, workbook, null);
                    excelType.InvokeMember("Quit", BindingFlags.InvokeMethod, null, excel, null);
                return "Done";
            catch (Exception)
                return "fail";
i use it in my pak. BriMohareb_XX to accsess excel and create some node like Run Macro from dynamo.
this is not necessarily the best option, but here is an example with OleDbConnection
it works fine with Sandbox and Civil, for Revit a workaround is necessary (need Microsoft Access Runtime)
the advantage is that by default it directly returns a DataSet or DataTable
test oledbconnection
C# Code
using System;
using System.IO;
using System.Collections.Generic;
using System.Data;
using System.Data.OleDb;
using System.Linq;
using System.Runtime.InteropServices;
using System.Reflection;
namespace ExcelUtils
    public class MyClass
        /// <summary>
        /// Workaround for Revit need to convert xlsx file to xls
        /// </summary>
        private static (string, bool) ConvertToXLS(string filepath)
            string hostAppName = System.Diagnostics.Process.GetCurrentProcess().ProcessName;
            string pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFiles);
            bool is_access_install = System.IO.Directory.GetFiles(pf_path + "\\Microsoft Office", "*MSACCESS.EXE", System.IO.SearchOption.AllDirectories).Length > 0;
            if (!is_access_install && hostAppName == "Revit")
                throw new Exception("Microsoft Access Runtime is not Installed\nhttps://www.microsoft.com/fr-fr/download/details.aspx?id=39358\n");
            if (filepath.EndsWith("xlsx") && hostAppName == "Revit")
                object excel = Activator.CreateInstance(Type.GetTypeFromProgID("Excel.Application"));
                excel.GetType().InvokeMember("Visible", BindingFlags.SetProperty, null, excel, new object[] { false });
                excel.GetType().InvokeMember("DisplayAlerts", BindingFlags.SetProperty, null, excel, new object[] { false });
                object workbooks = excel.GetType().InvokeMember("Workbooks", BindingFlags.GetProperty, null, excel, null);
                object wb = workbooks.GetType().InvokeMember("Open", BindingFlags.InvokeMethod, null, workbooks, new object[] { filepath });
                // convert xlsx to xls extension
                string newpath = filepath.Remove(filepath.Length - 1);
                // Use late binding to saveAs to xls (56 == XlFileFormat.xlExcel8)
                wb.GetType().InvokeMember("SaveAs", BindingFlags.InvokeMethod, null, wb, new object[] { newpath, 56, null, null, null, null, null, null, null, null});
                wb.GetType().InvokeMember("Close", BindingFlags.InvokeMethod, null, wb, null);
                excel.GetType().InvokeMember("Quit", BindingFlags.InvokeMethod, null, excel, null);
                Marshal.ReleaseComObject(wb);
                wb = null;
                Marshal.ReleaseComObject(excel);
                excel = null;
                return (newpath, true);
            else
                return (filepath, false);
        private static List<object> ConvertToArray(System.Data.DataSet dtSet)
            List<object> lstout = new List<object>();
            foreach (System.Data.DataTable dt in dtSet.Tables)
                object[] objectArray = dt.Rows.Cast<DataRow>().AsEnumerable().Select(r => r.ItemArray.Select(c => c == DBNull.Value ? "" : c).ToArray()).ToArray();
                lstout.Add(objectArray);
            return lstout;
        public static dynamic ReadXlsx(string fileName, bool returnArray)
            (string fixFileName, bool xlsCreated) = ConvertToXLS(fileName);
            var connectionString = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" + fixFileName + ";Extended Properties=\"Excel 12.0;IMEX=1;HDR=NO;TypeGuessRows=0;ImportMixedTypes=Text\"";
            using (var conn = new OleDbConnection(connectionString))
                conn.Open();
                var sheets = conn.GetOleDbSchemaTable(OleDbSchemaGuid.Tables, new object[] { null, null, null, "TABLE" });
                using (var cmd = conn.CreateCommand())
                    cmd.CommandText = "SELECT * FROM [" + sheets.Rows[0]["TABLE_NAME"].ToString() + "] ";
                    var adapter = new OleDbDataAdapter(cmd);
                    var ds = new DataSet();
                    adapter.Fill(ds);
                    if (!returnArray)
                        return ds;
                    else
                        return ConvertToArray(ds);
I’m not making a zero touch node…
This is a Revit add-in, it’s not using Dynamo at all.
You should probably look here then :slight_smile:
