C# - Custom counter node trigger by periodic
I am new to Dynamo custom nodes development.
I have been trying to create a custom counter triggered by DateTime.Now using periodic run.
My understanding is that, since Dynamo 2.0 there is no longer the option to store persistent data into nodes, so, I created a custom Object that allows to (de)serialize into a XML file which it is store in the user temp folder to push and pull a number to later on increment it, it works in the console application.
But unfortunately when I try implement it in the custom node it does not work. I am trying to understand how Dynamo executes the node because I cant get my head around.
I have seen people implementing in similar logic but creating a sender and a receiver in two separated components instead of executing the entire task in a single node
Sample code here:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.DesignScript.Runtime;
using Autodesk.DesignScript.Interfaces;
using Autodesk.DesignScript.Geometry;
using De_SerializationXML;
namespace DynamoCounter
public class Counter
internal Counter ()
    public static int engine(DateTime time,int listLength, bool run, bool reset)
        int t = time.Second%1;
        Number n1 = new Number();
        Number n2;
        n1.numb = 0;
        if (run)
            n1.SerializeXML();
            n2 = Number.DeserializeXML();
            n1.numb = n2.numb+t;
            if (reset)
                n1.numb = 0;
        return n1.numb;
Probably the nodes you want to use are cached so it won’t update. That is a guess, I am not sure if that is the case.
You can find more information here:
And a topic with a similar question here:
(direct link to a solution where the number is updated in a periodic loop)
Found an example with proper implementation for Periodic Update in Dynamo for who ever is looking for similar implementation.
See link below:
