I wonder if anyone knows if there’s any methods in dynamo that (when you develop your own nodes with custom UI in c#) allows you to show your output in the canvas but calls the same calculation method again on your output from the first calculation? I would like to preform this until my function has converged. This will at the end result in a simulation when you run the node.
Please let me know if anything sounds unclear, kind of difficult to explain.
Sorry for this late reply, I’ve been having some strange issue with my account for more than a week and it wouldn’t let me log in so I created a new account which seems to work perfect.
Back to the topic, if the what you send results in an animation when then run button is pressed in Dynamo, then it’s exactly what I’m looking for, but I would like that to happen inside my node with the custom UI (made in Visual Studio c#).
I will attach a simple code that might be explaining what I mean little bit better.
The Node UI
The Node Core
So, what I would like this to do is to move the point along the x-axis as an animation when I klick the run button.
