Hello guys,
I want to use Bumblebee package to show “0” (string or int both dont work) values but it does not work. I wanted also change border style it did not work , too.
I am using Excel in German language. Can be that the problem??
Hello guys,
Hi Deniz,
Your setup looks a lot like the one on the Bumblebee GitBook page .
The only difference that I can discover is that @Konrad_K_Sobon uses an “xlsx” file path.
Maybe you can try if that makes a difference.
Thank you very much for your reply. I changed the format and it still does not work :S
The only difference is now the language.
It shows “Success” in output but in Excel there are not conditions.
I found the problem:
The problem is about FilePath input.
