Bulk modify type parameter value for a built-in category
Newbie here :slight_smile:
I’m looking for node that could help me “select” all types of a built-in category, without them necesseraly being present in the model, in order to batch modify a type parameter value.
To be more precise, here is an exemple of what I am looking for :
I have a template with a certain number of wall types already configured , but not modeled.
I would like to modify a type parameter value which will be set the same for all walls.
With Dynamo, I can only select elements by category that are already modeled. Is there a way to get all the elements of a certain category existing in the document but not the model?
I would appreciate any help I can get. Thank you !
Try Element.Types (Walls) and All Elements of Type.
Don’t know if that works
I believe WallTypes is the dropdown selection. :slight_smile:
hi
cordially
christian.stan
Note that Element Classes and All Elements of Class we’re called Element Types and All Elements of Type prior to Revit 2024.
hi, thank you for generalizing Mr. Jacob (I am under 2023.1)
edit
correction with a python node if you are on an earlier version
import sys
clr.AddReference('RevitAPI')
coll_walltype=FilteredElementCollector(doc).OfClass(WallType).ToElements()
OUT = coll_walltype
cordially
christian.stan
Me too
Thanks everyone !
@christian.stan solved it for me. I was looking under Categories, Types , FamilyTypes, ElementTypes etc… But never thought I should look under Class.
PS : I’m working with Revit 2023
try this node
it’s retrieve all family types without the need for modeling.
Thank you @Mahmoud_Mokhtar95
Unfortunatly, this node keeps returning nuls for some reason
