Hi all,
I’m required to check multiple Revit files ensuring a list of project parameters are existing and in the correct categories. I have managed to run this test for a current document (see post, however, this uses a currently document solution.
I then looked at using Orchid which can background open projects in its own format, this worked well and I had high hopes when I found the Document.Project Parameters node. However, this outputs a parameter element type:
which I’m struggling to work with. I then found this which I’ve tried to modify to fit my needs but when I extract the parameter information even the name; it not relaying the names of the project parameters, but some other list where I’m not too sure where it’s coming from.
Either way, I noticed that the orchid method is relaying 216 parameters when the Clockwork is relaying 305; which seems to be more accurate.
Does anyone know any reason why the Clockwork and Orchid method would be reporting a different number of parameters?
Is anyone aware of a way to input multiple documents into the clockwork Project Parameters node so it can check each one rather than current, Orchid has its own datatype which clockwork obviously won’t accept.
And apologises for the open-ended question, but any advice on tackling these issues? I’m a bit lost jumping between different packages, trying to patch together python, etc. I feel like I have all the pieces, I just can’t figure out to bring them together.
Many Thanks,
Joe
