Did the Document.ProjectParameters (Clockwork) stop in Revit 2023
This script use to work but now the parameter name sends out Null. Am I doing something wrong?
Thanks in advance
Test Upload.dyn (25.0 KB)
well this sucks it does work in revit 2020
In Revit 23, you must install the IronPython2.7 package
I think it is
OK so I am trying to eliminate the clockwork node and came up with another issue. why does this only list 1 name and not the three that is the same?
The API for parameters changed quite a bit in 2023 so it might be due to that (spec types, forge units etc.).
Unfortunately most package managers havent had time to sort out cross version management or IP2/CP3 support yet (even the Dynamo team didn’t get the integer change working in the official nodes to begin with).
With OOTB-Nodes its quite a hustle to get your problem solved. Just use an imperative language block:
And if you are just trying to get the parameter values you could just use Element.GetParameterValueByName with your list of parameter names.
As @GavinNicholls mentioned, this is due to an API change in Revit 2023. I fixed this last summer, but haven’t published a new package version yet.
You can download it from here and replace it in your package directory:
https://raw.githubusercontent.com/andydandy74/ClockworkForDynamo/master/nodes/2.x/Document.ProjectParameters.dyf
