"BriMohareb_2023" SendCommand
This topic was split from SendCommand in ExternalDocument - #6.
@Angel76
you can use “BriMohareb_2023” from dynamo Revit you can send comment to cad file
BriMohareb_2023 No puedo instalar las ultimas dos versiones, solo me deja la 4.0.0 pero no tiene el nodo de “sendcommandfilepath”
Download v 4.0.2 from dynamo package website. And insert it manually.
Can you translate the error?
The error says: “The specified path, filename, or both are too long.” I tried the newer versions (4.0.1 and 4.0.2) manually website and it doesn’t install either. I also tried changing the folder name.
https://drive.google.com/drive/folders/1OORLCgOFBLuM1hmSD6SnsVSxEf0i7aSN?usp=sharing
download from here
@Angel76
also i publich V 4.0.3 by remove Help file has long name may be it is the reason
Installation error, I will be attentive to your publication v 4.0.3
did you try download from the link i sent it to you?
V 4.0.3 take some time to download
Yes, I copied the drive files
Thanks I managed to install version 4.0.3 from the package browser
load this file add lmport library
It works, how could I save the AutoCad file after running?
:bouquet: :bouquet: :bouquet: :bouquet: final run
for save morgen i will create dynamo node for that. have fun
Thank you very much, I will be testing all the nodes, it would be great if you add your package to dynamo for Civil 3d
@Angel76
for save and close use V 4.0.4 :blush:
This is great, thank you very much. Excellent contribution.
