I want to take BoundingBox from Sectional View. But for some reason it is built elsewhere. If you take an example: They all turn around, the depth goes inside the leaf. And everyone moves. How do I get them where the sectional view is?
bounding boxes are always axis-aligned, moreover the bounding boxes of the sections have an internal transformation, so you can’t use it directly
you can use solids instead (using transformations)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
view = UnwrapElement(IN[0])
cpbbx = view.CropBox
tfBBx = cpbbx.Transform
DSbbx = BoundingBox.ByCorners(cpbbx.Min.ToPoint(), cpbbx.Max.ToPoint())
solid_ds = DSbbx.ToCuboid()
tfds = CoordinateSystem.ByOriginVectors(tfBBx.Origin.ToPoint(), tfBBx.BasisX.ToVector(), tfBBx.BasisY.ToVector(), tfBBx.BasisZ.ToVector())
OUT = solid_ds.Transform(tfds)
