Section Box not match bounding box
I got two questions here.
  1. I get the SectionBox in the current view and use this Section Box to create a bounding box. But
    the result is that the bounding box location is not the location of the Section Box. What’s the problem? How to fix it?
  2. The max and min XYZ values of section box was diferent with the bounding box I created.Why?
clr.AddReference("RevitAPI")
from Revit.Elements import *
A_view = doc.ActiveView.ToDSType(True)
av = doc.ActiveView.GetSectionBox()
x = av.Min.X
y = av.Min.Y
z = av.Min.Z
x1 = av.Max.X
y1 = av.Max.Y
z1 = av.Max.Z
bx = BoundingBoxXYZ()
bx.Min = XYZ((x), (y), (z))
bx.Max = XYZ((x1), (y1), (z1))
bbx = bx.ToProtoType()
OUT = [av, x, y, z, x1, y1, z1, bbx]
Hello @A.C
try this (transform of an 3DSectionbox is not null)
tf = av.Transform
pta = tf.OfPoint(av.Min)
ptb = tf.OfPoint(av.Max)
DSbbx = BoundingBox.ByCorners(pta.ToPoint(), ptb.ToPoint())
OUT = DSbbx
