How can I get Bounding Box or WorkPlane from Section View?
I know there is a node(or python) for getting Section View from BoundingBox,
Then, how can I get BoundingBox or Workplane from Section Vew?
I searched everywhere, but I can’t find any clue.
# s = your_selected_section
# av = active view
s.get_BoundingBox(av)
s.Min
s.Max
Thanks for the answer.
But I’m not sure how to use what you wrote.(it doesn’t seem like for Python…)
May I ask you to write full code of usage example?
Thanks in advance.
Hello @Hyunu_Kim
here an example
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
view = UnwrapElement(IN[0])
cpbbx = view.CropBox
tfBBx = cpbbx.Transform
newBBx = BoundingBoxXYZ()
newBBx.Min = tfBBx.OfPoint(cpbbx.Min)
newBBx.Max = tfBBx.OfPoint(cpbbx.Max)
ddsBBx = DS.BoundingBox.ByCorners(newBBx.Min.ToPoint(), newBBx.Max.ToPoint())
OUT = ddsBBx
Oh ,Thanks poupin. I’ll try with it. :slight_smile:
