BimorphNodes V4.0 Released - Rebuilt for Revit 2022
I think I found the mistake. I don’t close first project and if it stays open then I get that warning. When I close the project and run script it works without any problems…
If you skip step 7 you should get same warning.
Perfect, yep, I can reproduce the exception now. Will post back once I discover the cause and fix it. Thanks for reporting it.
Thank you very much Thomas!
Hello @Thomas_Mahon,
I am getting that kind of an exception. Have you ever encountered that?
PS: The elements can contain “;. + or :”. Why is it problematic to get that kind of data?
PS 2: When I explode all blocks, it works.
Using Revit 2022.1 with Dynamo 2.12 I can’t seem to get Linked CAD hosted levels. I’m suspecting the installation of Orchid has something to do with it.
What can I do to obtain the level anyway?
