Hello all,
I’m fairly new to Dynamo and am running in an issue when using the node mentioned in the title. The result should create a list of all sheet names in the chosen schedule, however, when I use it, I just get a list of numbers (element IDs?). I am using Dynamo v1.3.4.6666 and BimorphNodes v3.0.3. I’ll attach pictures. The first is the desired result, and the second is the actual result. Thank you for any help!
