Bearer token and Api-key
Hi all,
To access an api I need to place a header and an authorization, with postman I can access the webservice I’m interested in but with dynaweb I get stuck
Any idea?
With postman, for Authorization (bearer token)
And Header (Api-key)
The results it’s ok, but with dynaweb:
Thanks for your help…
Can you expand out the “code” area in Postman and compare the two requests to see if it is a formatting thing or a header issue?
For me it’s a same
I added “Bearer” in my code bloc
After relaunch revit and dynamo it’s ok !!!
thanks for all
