Hi there,
I created a steel structure in dynamo with Structural Design package by following this tutorial: https://youtu.be/k6TwRcK_id0
It created the frames with a pitched roof which is fine by me however I noticed that the sloped girders miter connect to each other at ridge level.
I need them to be straight cut: I can achieve that manually in Revit via the beam/column joins command.
Is there a way to accomplish the task in Dynamo?
Thanks in advance for your help.
please see attached dynamo graph, 3D structure model and a PDF file with description of the beam-column joins I wish to change in Dynamo.
Thanks for your help.
Regards,
BeamColumnJoins.pdf (207.0 KB) ProvaStrutturaPortale2.dyn (248.7 KB)
check this ProvaStrutturaPortale2.dyn (254.7 KB)
i also made changes in the column braces:
Hi @blsalvio,
thank you for your contribute and help: your solution is working!
However I did find other issues arising with the bracings and columns.
See attached pdf description file (page 2) and my revit file.
BeamColumnJoins_R1.pdf (301.1 KB) ProvaCapannoneTutorial+DynForum.rvt (2.1 MB)
Thanks again.
Please mark my solution as the solution to your original question because I think I have solved it. For another question not related or a question supplimentary to your original question, please make another topic about it.
